Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Lamona HJA3300 only working on grill & turbo fan
- This topic has 5 replies, 2 voices, and was last updated 12 years, 1 month ago by
j0hnnyb0y.
March 23, 2014 at 10:29 am #80061
j0hnnyb0y
ParticipantHi,
I have just been given an oven that only works on grill and turbo fan. I think turbo fan is only a pre-heat setting. The person who gave it to me has used the oven on turbo fan for 3 months for all cooking, it just cooks a little hot. On standard fan setting the light comes on and the fan works but no heat. I have searched the web and found others with this problem but no fixes have been posted. If the oven works on turbo fan I imagine it’s not the element or maybe there are 2 elements ???. Before I take it apart I would like to know if anybody has knowledge of this fault.
March 23, 2014 at 11:06 am #411525kwatt
KeymasterRe: Lamona HJA3300 only working on grill & turbo fan
On turbo mode, basically, all that happens is that all the elements are brought on all at one time to heat the oven cavity as quickly as possible.
I’d bet that it’s just the fan element that’s gone so it’s cooking using the upper element (with grill) and lower heating element if fitted with the fan running.
If I’m correct and, I’m pretty confident that I will be, then you need one of either of these:
http://shop.ukwhitegoods.co.uk/30018038 … en-element
http://shop.ukwhitegoods.co.uk/ele2033-fan-oven-element
Of course you’d have to check the element to be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain.
March 23, 2014 at 1:52 pm #411526j0hnnyb0y
ParticipantRe: Lamona HJA3300 only working on grill & turbo fan
Thanks for the reply kwatt,
I have just tested the element inside the oven around the fan, continuity ok, also the element heats up when oven is set to fan/turbo, when checked again with standard fan setting element is cold
March 23, 2014 at 2:30 pm #411527kwatt
Switch probably then, odd but not unknown.
http://shop.ukwhitegoods.co.uk/30018041 … tor-switch
March 23, 2014 at 3:20 pm #411528j0hnnyb0y
Just one last question before I purchase the switch, first turn of the dial is light only – all ok, second turn of the dial is standard fan – fan starts but element stays cold – third turn of dial turbo fan – fan starts and element heats up, do you think switch in standard fan mode can operate light and fan but be faulty on operating the element.
Thanks for the assistance
March 23, 2014 at 3:24 pm #411529kwatt
Yes, the switch essentially makes or breaks power to the element but the thermostat is also in circuit to cut it in and out.
However, if the oven doesn’t overheat on turbo then the stat should be okay and, in any event, if the stat was OC then I don’t think it’d work at all but, that is dependent on how it’s wired of course.
It will be relatively simple to work it out with a meter and some patience.
