Lamona HJA3400
  • #79489
    Johncharles57
    Taking along time to cook food,bottom of oven not getting very hot, oven temperature
    Seems to be working red light going out when reaches temperature,fan at rear of
    Oven not working .
    #409436
    Re: Lamona HJA3400
    If the fan at the back of the oven isn’t working then you will need to find out why.
    If it is the fan motor that is faulty then it’s this one:
    http://shop.ukwhitegoods.co.uk/264440102-oven-fan-motor
    However, there are also other things that could give you a similar fault but you will need to investigate further to determine what the issue is.
