Lamona HJA4620 (double oven) Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Lamona HJA4620 (double oven) This topic has 1 reply, 2 voices, and was last updated 12 years ago by rocker. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts March 14, 2014 at 3:23 pm #79947 rockerParticipant Looking for the (cut in/cut out) cooling fan thermostate for the main oven. it has 3 wire connections on the original. The cooling fan runs continually, so I am assuming this is the fault, unless anyone can advise of another know cause. thanks John March 15, 2014 at 4:53 pm #411157 electrofixModerator Re: Lamona HJA4620 (double oven) from what i can see the part you want is 263410018 cooling motor thermostat but only seems to have 2 connections but you need to check if its closed circuit with the wires off Dave ps if you pm me vyou email will send you Beko info Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
