Re: Lamona HJA6110 ice dispenser
I had to replace a faulty flap solenoid on this model a while ago.
If I remember it may have 2 screws underneath where the water comes out in the dispenser.
The screws need to be taken out first then just lever of the display surround carefully with a flat screwdriver starting at the bottom then work up the sides.
Go carefully as the display is not one piece but 2 and is joined with 2 screws from behind but it removes in 1 piece.
If no screws are visible underneath where the water comes out of the dispenser then it just levers off.
When you put the display surround back on it just clips on so you have to hit it with the side of your hand around the edges to clip it back on.
Hope this helps
Bob
