Lamona HJA8630 dishwasher
  • #73854
    qcarelsen
    We went to visit a property and found that after the machine has been on a cycle it keeps steaming and heating and does not continue onto the next part of the cycle. Does anybody know what could be causing this as I have found this same fault on two of these in a week.
    Thanks.
    #389081
    BobHope
    Re: Lamona HJA8630 dishwasher
    its the door mounted PCB, the relay melts, cheap as chips to relplace.
    Bob.
    #389082
    qcarelsen
    Thanks Bob, have you got a part number for me, O and one more thing, the other one we went out to stopped heating at all,will this be the same fault
    #389083
    BobHope
    do you have the product code ?.
    bob
    #389084
    qcarelsen
    The only other number I have got is 95735 and R-54
    #389085
    BobHope
    more than likely product code 7676383842 and the info is just below this post second one down.
    Bob.
    #389086
    qcarelsen
    Hi Bob,
    Thanks for that, I did think it was the PCB but wasn’t sure, as the first time I heard about this problem was when the customer phoned me due to no heat any more, so I was very unsure about this one as the heater reads fine and there is power going to the heater, do you reckon it still is the same problem, I think it is but I am just double checking.
    #389087
    BobHope
    all the 5 i have done were the pcb and the heater relay was bulged or melted, symptoms of no heat or heatng all the time depending on the heter relay welded together or open circuit.
    Bob.
    #389088
    qcarelsen
    Thanks Bob, I will go for PCB then, as I am 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure heater is fine. Cheers, and thanks again.
    #389089
    BobHope
    you can check the heater from the pcb connections without taking the appliance out.the heater relay is in one corner and the 2 heavy heater wires areeasy to spot.
    Bob.
    #389090
    qcarelsen
    Thanks that is a good tip, it is the 2 purple wires, but I normally check it from the bottom without pulling the appliance out if the kick board comes of easy.
