Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Lamona HJA8630 dishwasher – all programme lights on
- This topic has 6 replies, 6 voices, and was last updated 12 years, 4 months ago by
P Mellor.
December 4, 2013 at 2:08 pm #78455
P Mellor
ParticipantOur Lamona HJA8630 dishwasher from Howdens is displaying all the programme lights and we can’t get it to reset so it won’t start. This has been an intermitant problem before but would eventually reset, but won’t do this time. We were never given a manual so can’t check.
December 7, 2013 at 3:55 pm #405749Seamy
ParticipantRe: Lamona HJA8630 dishwasher – all programme lights on
Likely the p.c.b needs replaced, under where the buttons are, they can get corroded.
December 7, 2013 at 4:24 pm #405750keithwilliams
yes its the pcb. have replaced a few and keep them on van.
good news is that they aren’t expensive. your dishwasher is the same as a beko dw600. and dont be put off by it being a beko. i personally think they are the best value dishwasher to have.
smeg pcb are about £150 trade yours is about £16.December 14, 2017 at 9:56 am #405751twicknix
Is it just the module or display module.
December 14, 2017 at 3:50 pm #405752keithwilliams
It’s the module. However I’ve since discovered that you can cure this by replacing the large grew capacitor. So if you fit s new mod, keep old one repair it.
May 27, 2020 at 2:24 pm #405753Brian Fields
ParticipantRef Keith Williams reply. I replaced both electrolytic capacitors on the main board and it cured the “all lights on” on display panel problem on my neighbour’s machine. He’s extremely pleased – and so am I. It proves that I’ve not lost the plot yet after 45 years of electronic engineering.
However, the point is that it’s not what you may know – it’s what others can teach you!
Thanks Keith!May 27, 2020 at 7:06 pm #405754electrofix
Moderatorkeithwilliams wrote:Re: Lamona HJA8630 dishwasher – all programme lights on
spot on, done lots, common fault. Also same fault can cause the heater relay to burn out meaning the heater wont swich off while there is water in
