Hi all, I have the above Howdens/ Lamona washer dryer stopping mid cycle with 7 flashes which I believe is motor fault. Motor checks out ok, brushes, taco, insulation and seems to run ok when I try it. I’ve checked out everything else I can think of on the machine. Put it on quick wash when i was there and it washed and heated but got call to say it stopped mid cycle with 7 flashes again after I left.
Any ideas please?
Thanks for reply. My problem is the motor is working fine, or seems to be. Unless there’s a sock or something stuck between the drum and tub that is jamming it now and again. Customer days when it stops mid cycle she spins the water out ok.
