Lamona HJA8703 Pumps for 4 minutes.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lamona HJA8703 Pumps for 4 minutes.
  • #74090
    Twoten
    Regardless of the program selected the door locks and then the pump runs for about 4 minutes.
    It does not display any fault codes.
    The machine switches of if selector in the off position otherwise it doesn’t make any difference.
    Is this more likely to be selector or PCB?
    #389945
    Seamy
    Re: Lamona HJA8703 Pumps for 4 minutes.
    Check float switch in base, if theres a fault with it you get a pump running continuously & nothing else.
    Some other things to look out for on Beko type dishwashers, not sure if this is the Beko type Lamona dishwasher, (maybe someone can clarify) is the flowmeter or the small cable to it being damaged in loom.
    #389946
    Twoten
    Seamy wrote:Check float switch in base, if theres a fault with it you get a pump running continuously & nothing else.
    Thanks Seamy,
    This is a Washer/Dryer, same as the Hoover/Candy machines.
    The machine has an open base and I couldn’t see any float switches in the bottom rails.
    The water level is controlled by the conventional pressure chamber which checks out OK.
    #389947
    smartin
    megger the heater, it will more than likely be down to earth.
    #389948
    Twoten
    smartin wrote:megger the heater, it will more than likely be down to earth.
    I checked for earth faults, the machine was clear.
    #389949
    I’m thinking the pressure switch (91201369) is stuck on the anti flood level and replacing it should cure hopefully? Does the Start LED flash at all?
    #389950
    Seamy
    There was me thinking it was a dishwasher,
    :eeek: RODNEY :eeek:
