LAMONA HJA8704 Door locked
  • #63846
    LittleMan
    just had a call about this machine door locked.she has had same problem with in the 1st year called engineer in he pressed 2 butons and door opened can any one help it has a flashing rapid light and 90 min display is flashing
    Les
    #355188
    Re: LAMONA HJA8704 Door locked
    if its a standard interlock should open if you pull the plug and wait 4 mins
    its supplied by howden joinery hence model HJ etc
    from all info on this forum ( search for HJA8704 and search for lamona) they are a pile of tat. seems to me the enginner nust have done some sort of reset of some kind before so its trial and error unless another member knows better. if the interlock is not a bi-metal there may well be an emergency release mech
