Lamona Hob HJA1613
  • #77691
    djohnston
    Hi could anyone tell me what fault code F81 is on this model.
    Many thanks
    #403056
    Re: Lamona Hob HJA1613
    this is a Beko and they have surpassed themselves by the lack of information given
    there is a list of fault codes but no description about what they all mean and there is not an F81 fault as the list only goes as high as F63
    also the troubleshooter is as good as useless as right in the middle it asks is the comutator faulty
    but looking at this there is not a lot of stuff in it so my guessing is the board is faulty. you can check continuity of rings for open circuit etc
    this should be part number 663260131
    full info
    prod code 7756286353
    HJA1613
    can send you wiring diag if you need but the rest of the info is not nuch good
    EFS
    Before you jump in and start fitting expensive spares Howdens are having a sale at the moment and the current model is only £189.99+VAT
    or the induction hob at £249.99 + VAT with two years warranty.
    Steve
    #403058
    A1engineer
    insualtion faults can throw up funny codes 🙂
