hi lads this has just light on no compressor noise . got a small pcb as a thermostate control . do these cause it not to run ? any one changed one with success to get comp running or is more likely to be a scrap job ?thanks ?
If it is like the free standing ones it will be on the back of the machine, and it will have to come out to replace i’ve had 2 or 3 of the bog standard ones not running and it was the pcb.
hi this model aint showing meny parts tho 🙁 , do any of you have the part nos i will be needing ? is it the same as a beko bc73f board i am needing ?cheers?
If the beko board looks the same then it looks like it uses a capacitor power supply so it would be very possible that it just needs the X2 class capacitor changing – I have not done it on this model but do this repair regularly on various other fridges and freezers for no life faults with considerable success.
