Lamona LAM8302 – No start flashing start indicator
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Lamona LAM8302 – No start flashing start indicator
  • #100723
    Rake
    Hi all, desperate for some help please
    as above the LAM8302 has P1 not flashing and the triangle start / cancel indicator flashes constantly and the machine will not start.
    cleared filter, added salt, reset at plug but no difference.
    any help gratefully received
    thanks
    #481900
    does not come up as a fault code
    I think I would check door switch first. if its not working the unit will think door is open and wont start
    Rake
    electrofix wrote:does not come up as a fault code
    thanks – where and how do I check the door switch please ?
    #481902
    door switch is in the top of the door. you need to access it and make sure the contact is opening and closing when the door is
    Rake
    Ok found the door switch and activated it with a screwdriver and the machine came on, returned it to off but when I close the door it still won’t come on, the tongue on the washer side is present but I don’t think it’s activating the door switch – any fixes for this ?
    thanks
    #481904
    Rake
    Update – who’s a silly wife – looks like she pressed something that caused this issue. I pressed the P button continuously and the flashing start icon changed and allowed the thing to work !
