Lamona LAM8605
  • #102174
    Hollytree_Technical
    Hi all
    Prod: 7632253842
    Can someone send me the service info for this machine please, it refuses to heat or open the tablet dispenser but all the wiring and element checks out as good, the NTC was also giving a believable reading (though I don’t know what the correct value should be) so I tried replacing the module but that didn’t cure it.
    I have got an NTC on order to compare with the existing one but would like to be able to access service and test modes if possible.
    Thank you
    Jem
    #487831
    sorted
    Hollytree_Technical
    Thank you
    Jem
    #487833
    Hollytree_Technical
    Turns out that it was the NTC and that it should be around 44K at 20C
    Jem
    #487834
    rickard
    I have one of these which beeps when you close the door and registers a program but nothing starts I have checked all componants but they seem all ok. Any help would be much appreciated
    #487835
    have you checked door wires for breaks ?
    would expect pump to run first assume its not jammed
    have emailed a few files
    rickard
    Thanks for the info Dave. No breaks in the door wires just beeps to start then nothing. No pump as you would expect
    Andy
    #487837
    see if the self test will work
    after that sounds like it may be the board
    have you opened the board and checked for damage ?
    rickard
    Morning Dave Thanks for your reply. No the test program wont work either and no damage to the board just completely dead after the start beep. I have quoted for a new board
