I’m needing to replace the element in my Lamona (LAM3600) oven. The actual element doesn’t have any screws to remove it, more like soldered dots?? How is the best way to remove it so I can fit the new element?
Most you can do from the front without taking the oven out but, if it’s not got screw heads you’ll likely have to pull the oven out the housing to replace it.
