Lamona Range 4401 Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Lamona Range 4401 This topic has 8 replies, 3 voices, and was last updated 1 year, 4 months ago by Raovencleaning. Viewing 9 posts - 1 through 9 (of 9 total) Author Posts November 24, 2024 at 10:25 am #103091 RaovencleaningParticipant Hi guys hoping you can help. The cooling fan is permanently going, this started after the mains switch needed replacing. I’ve checked 2 thermal switches but both seem OK, any ideas where to go next? Cheers Rob November 24, 2024 at 7:47 pm #491748 electrofixModerator is that the accurate model no from the rating plate ? Dave November 24, 2024 at 8:07 pm #491749 RaovencleaningParticipant It just says Lam4401 sorry should have put it all. November 24, 2024 at 10:00 pm #491750 electrofixModerator when you say you changed the mains sw I assume you mean the switch on the wall not a switch on the cooker check the grill door sw and if thats ok check the front contact on the top oven control sw Dave November 25, 2024 at 6:40 am #491751 RaovencleaningParticipant Yes I did mean the switch on the wall. Thanks very much for your suggestions Dave I’ll check those. Cheers Rob December 8, 2024 at 8:50 pm #491752 electrofixModerator that switch is the thermostat. if that fails it will do everything except heat will not make cooling fan run all the time Dave December 8, 2024 at 9:07 pm #491753 RaovencleaningParticipant Cheers for letting me know! December 10, 2024 at 1:21 pm #491754 RachelInouyeBlocked Same here. December 10, 2024 at 7:14 pm #491755 RaovencleaningParticipant It seems to be quite a common problem then. Author Posts Viewing 9 posts - 1 through 9 (of 9 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
