Lamona Washing Machine HJA8514
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Lamona Washing Machine HJA8514
  • #61638
    Taff
    This machine is washing fine but on rinse cycle the machine overfills, as though its loosing water,i.e. fills for about 6 seconds and stops then fills again for 6 seconds. I have fitted a new pressure switch and checked the chamber and pipe. I don’t think it can be these as it would overfill on wash. The board has been sent for test to EMW. I just don’t understand why it only does this on rinse cycle. Any ideas please??
    #347014
    Johnokent
    Re: Lamona Washing Machine HJA8514
    You dont say if this cycle continues or not. water is not siphoning away is it? Have you checked waste pipe level. May be ok for wash level but to low for rinse level.
    #347015
    Taff
    No the water isnt siphoning, the cycle just continues to over fill? The waiste pipe is well above the water level. I have tried this with the drain pipe above the kitchen work top draining into a bowl.
    #347016
    What is the state of the pressure tube? Has it been rubbing on anything, causing a tiddly little hole which is insufficient to cause a problem until the higher pressure of high water level opens it? I’ve never had that but it sounds good, doesn’t it?
    Mike.
    #347017
    Johnokent
    I did have a small leak like this a while ago on a hotpoint machine, it took me a while to find it because the machine washed and rinsed ok when empty but as soon as clothes were added it over filled repeatedly, as in this machine. Like you I suspected pressure switch, siphoning, leaking gaskets etc. in the end I changed the pressure switch hose and it solved the problem.
    On close examination,of the old hose and with the help of a bubble liquid I eventually found a microscopic hole in a slightly chaffed area. I can only assume the extra weight of washing stretched the tube slightly and allowed it to weep the pressure away.
    Just any idea
    John
    #347018
    Taff
    Customer has given up and bought a new machine. I will pick the old one up and I will find out whats wrong this blasted machine. Like a dog with a bone!!!
    #347019
    Johnokent
    I’ll be interested to know what you find.
    John
