Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › larger water heater on samsung refregator model rs253baww
- This topic has 6 replies, 2 voices, and was last updated 13 years, 8 months ago by
geoanth.
August 1, 2012 at 5:07 pm #70747
geoanth
Participantupdated water heater da47-00200c 15×8 inches is bigger than in place heater 11×11.5 inches which is open.how do i fit it in place on top of the original heater? It,s a peel and stick upgrade. thanks so much for any help.
August 1, 2012 at 5:26 pm #378841admin
KeymasterRe: larger water heater on samsung refregator model rs253baw
Why are you replacing this ?
Bryan
August 1, 2012 at 6:15 pm #378842geoanth
ParticipantRe: larger water heater on samsung refregator model rs253baw
original water heater is open, won,t defrost evap.
August 1, 2012 at 6:28 pm #378843admin
Then this heater is as much use as a chocolate mug…
The heater you require is a defrost heater,Is this a UK model ?
Bryan
August 1, 2012 at 9:37 pm #378844geoanth
its an american model as indicated by the model number.i wouldn,t be interested in changing out a good defrost heater.although it would be good business for suppliers.samsung made a field change to the defrost heater to cure an icing problem,freezing the drain hole and spilling water out of the bottom of the unit on to the floor.i,am sure you are aware of this major complaint!!! my problem is the upgraded defrost heater is larger than the original heater which i have but without a diagram to position it because it extends higher up on the evap cover onto the plastic evap blower motor frame.it is the right heater but samsung doesn,t want the home owner to make these repaires because of liability hence my attempt to get info on this site to position it properly over the original heater.
August 2, 2012 at 4:33 am #378845admin
This model is an American STYLE.the model has several variations which were sold including a 110v which is why the question was asked whether you purchased it in the UK . The heater you have is NOT a defrost heater it is an evaporator cover heater.
Bryan
August 2, 2012 at 1:50 pm #378846geoanth
hi BRYAN. LOOKING INTO YOUR REPLY [THANKS] ON THIS IS EVAP COVER HEATER AND NOT EVAP DEFROST HEATER DID MEASURE THE VOLTAGE AND IT IS 110V OUT OF THE FEMALE END OF PLUG.IDO HAVE AN EXPANDED VIEW OF THE EVAP SECTION TO LOOK AT.WILL REMOVE THE EVAP COVER SOON AN DEFROST TO SEE IF THERE IS A HEATER DIRECTLY ON THE EVAP IT- SELF THAT I HAVE MISSED.tHANKS AGAIN FOR YOUR HELP!!
