Original fault fans not working .Ordered new board . Old board has lead soldered on panel leading to fan switch operated by door .New board no lead on panel can anybody tell me if wrong board supplied or wireing mod. reqd. thanks
Re: Larp fridge Model AB5000PV S/N 00NA33140 Power board fau
Just to say it is a wiring modification required .Pull wire off pin 6 on power board and join to lead from door switch. The other lead from the door switch is fitted to pin 6 on the power board .
