Latch for LG WD1045FH required (not entire door assembly)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Latch for LG WD1045FH required (not entire door assembly)
  • #26442
    dazzawazza
    The latch on my LG WD1045FH has broken and I’m trying to source the part, which I have removed from the door. I have spent quite a while searching the Internet and can only find the door assembly, which includes the latch for £40. Surely the latch is available by itself for much less. Can anyone help me with this? Thanks
    #210179
    bazza500
    Re: Latch for LG WD1045FH required (not entire door assembly
    Checked LG wesite and it`s complete door or nothing I`m afraid.
    #210180
    dazzawazza
    Thanks Bazza.
    So not a complete waste then??
    I have managed to keep the machine working by propping something against the door. Will try and fix the latch somehow before inevitably buying the complete door.
    #210181
    dazzawazza
    Is there anywhere that sells second-hand parts off wrecked appliances?
    I live in London. Thanks
    #210182
    dazzawazza wrote:Is there anywhere that sells second-hand parts off wrecked appliances?
    Not really unless someone local just happens to have one. Second hand spares are a non-starter due to the number of them out there.
    Maclee
    A long shot, but try looking around your local rubbish tip… WHOOPS! I mean ‘recycling centre’ 🙂
    White goods usually have their own area, so if there is a machine present you should see it easily.
    #210184
    Maclee wrote:A long shot, but try looking around your local rubbish tip… WHOOPS! I mean ‘recycling centre’ 🙂
    It would be a long shot, as Kwatt says due to the small number of these machines sold, you would be unlikely to find one under the huge mountain of Italian made machines on top of it. 😥
    You could try p/no 3650ER3002A. spares@ukwhitegoods.co.uk will get you one if you email through with the part number.
    bazza500
    penguin, that`s the part no. for the door handle, not the latch.
    #210187
    Last one I bought was a kit.
    P45.
    #210188
    bazza500
    Mmmmm…… I`d watch that then cause I`ve bought just the handle before.
    The picture on connect is just the handle but……
    It makes more sense to sell it as a kit but then when did sense come into it?
