late service module
  • #11289
    simonb
    hello all
    took away service module off late type machines module located at top of machine has minisel 546039600-01 ,no motor action fault(dead) brushes ok machine less than 2 years old i noticed back at base on track side a dry joint located under main three relays, i know on other merloni boards blob of solder normally does the trick, couldent try it as only realised missing when took it away before i order another board anyone come across this, is it a componant failure or solder come away, also very slight blackish burn mark with the dry joint??
    simonb
    #144668
    Re: late service module
    Probably the forward/reverse relay Simon. Reinforce the joint with some single strand wire and resolder. Should be OK…….. Failing that EMW do them at a very reasonable rate.
    simonb
    thanks chris think ill give it a try
