Got a late Hoover washer dryer tripped dryer stat. Customer had large bath sheets in so reset and told to try. Tripped again, is condenser cleanable on these or any filters in heater box? Had a very brief look at back not like old old ones with visible condenser. Thank you.
It is not removable only way to clean is with a coat hanger is 1 of those jobs that will probably come back after a week or so unless you spend a lot of time cleaning. Remove heater box then you can probably get access also clean the veins on the dryer motor fan they block up as well 😕 Good luck kai
