Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Later type Bosch/ Neff/ Siemens dishwashers
- This topic has 8 replies, 6 voices, and was last updated 11 years, 4 months ago by
chitts.
November 30, 2014 at 9:47 am #83225
chitts
ParticipantCan anyone offer advice please.
I have 3 BSH dishwashers, all 3 years ish old, with intermittent flood protection operation. One seems to be detergent related as the customer changed to Finish with no problem, then used another brand and fault reoccurred. The other 2 seem OK then totally at random shut down. Having had all 3 machines in the workshop on test with the panels off, they’ve all done 10-12 hot washes with no problems. When returning to the customers all seems fine, then same fault.
I’ve warned them that opening the door when in use can cause problems, and all assure me that doen’t happen.
I know the flood prection system is more sensitive on these newer machines, and there is signs of water in their bases, but the machines seem to reset overnight, I guess through evaporation.
ANY input most welcome. I’ve wasted so much time already, to no avail.November 30, 2014 at 10:49 am #422114lee8
ParticipantRe: Later type Bosch/ Neff/ Siemens dishwashers
It’s a known issue. Check location in case condensation is forming inside appliance.
November 30, 2014 at 1:42 pm #422115nomadPaul
If its the full metal tub version, it may be leaking from the tub sump seal. There’s a repair kit for that which consists of a small rubber seal fitted between the tub and sump.
If its the plastic base/bottom machine then there can be leaks from the outer edges where the tub sits in the base. This normally shows up as a yellowy residue at the join on rear or sides where the tub sits in the base ‘groove’.December 4, 2014 at 3:51 pm #422116chitts
All metal tubs, no sign of leaking from the sump,( I’ve had that and perforations in the tub), so I’m stumped, especially as both the other machines haven’t played up for over a week now!! I’m thinking more “dodgy detergent” now than ever.
December 4, 2014 at 4:03 pm #422117Martin
ParticipantLater type Bosch/ Neff/ Siemens dishwashers
I would doubt detergent overfoaming an issue, not on a full sized dishwasher like this. Rinse aid possibly but not detergent. The tub seal, as Paul said, is a recognised problem and THE most likely IMHO.
In your workshop test you could overdose the detergent to prove a point. 💡
December 6, 2014 at 11:33 pm #422118twicknix
Wondering if water softener putting out too much salt?
December 6, 2014 at 11:40 pm #422119Martin
twicknix wrote:Wondering if water softener putting out too much salt?
We can rule out that as being impossible.
December 10, 2014 at 6:10 am #422120chitts
All these machines currently still OK! Had a Miele doing same thing this week.
Took off the panels cleared water from the base and watched through a normal cycle, no leaks. Customer has used every day since, no problems.
When I warned against opening the door when machine in use and hot, she said that they do, and always have. Could explain the problem, as the pressure build up when closing the door is considerable.December 11, 2014 at 1:48 am #422121aqualectric
I’ve had this problem several times. The common factor on all the Bosch machines I’ve seen is they only leaked if the intensive cycle is selected and the water appears right at the end of the hot last rinse. I tried all the other cycles and none leaked at all. Just the intensive cycle and just at the end. And always from the back of the sump on the left side looking from the front above the diverter valve.
Fitted a new tub to sump seal in all cases and all OK. As others have said, it’s a known issue.HTH,
Steve.
