Lavamat 12700 VI Turbo every program goes directly to the last 3 minutes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Lavamat 12700 VI Turbo every program goes directly to the last 3 minutes
  • #99937
    jjbarriga
    Hi.
    My AEG Lavamat 12700 VI Turbo has the following problem.
    I can properly select any program, it displays the correct time of the program, but when I press start, after a couple of seconds the machines jumps to the latest stage of the program and displays 3 minutes left to finish and in fact it finishes properly, ulocking the door as if everything went normal.
    No error code is shown.
    It seems that some sensor is providing some wrong information and preventing the machine go through all the washing stages.
    Any ideas to what I should look for?
    Any help is appreciated.
    Jose
    [h=1][/h]
    #478538
    some error codes are not shown to the user
    jjbarriga
    Hi.
    Is there a way to show the error codes?
    Jose
    #478540
    you would have to put the machine into service mode to be able to get hidden fault codes. normally its press and 2 buttons while turning on. which 2 will depend on the exact model and panel configuration
    try doing a utube search and see if you can find one like yours
    andyjawa
    Well there are 17 versions to your model – the product code begins with 9 – but basing that it is possibly only cosmetic ( but might not be ) have a look at the motor brushes before doing anything else. They could well be worn out. For the machine to function they wire it through the motor. Also check that the tacho motor coil has not fallen off the back of the motor OR the tacho magnet has not come loose and has fallen off within the coil, the latter is not visually obvious, usually from memory it is an unscrewed magnet that 70{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time causes your problem..
