Lavamat 14850 PCB or controller
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Lavamat 14850 PCB or controller
  • #59034
    123dec45
    I have a dead AEG Lavamat. Was working fine, turned off and on and now the display/everything is dead.
    I checked the obvious, fuses,rcd’s etc all fine. I checked the suppresor and its also fine. Looking at the back of the controller, none of the capacitors are bulged, no scorching on the board, Same on the PCB. Question, is there anyway of establishing which is u/s ie the controller or the PCB? Given the PCB has a replacement cost of circa 45 and the controller 200 +, sod’s law says its the controller, can I get either tested, (I have removed both from the machine)
    cheers
    #336551
    Seamy
    Re: Lavamat 14850 PCB or controller
    Multimeter would be the first thing to use, to establish if theres supply to appliance.
    This is a washer dryer appliance so should be worth repairing.
    You will need the product number when ordering spares as there are 8 different models with this number.
    http://shop.aeg.co.uk/node13.aspx
