Le Germania – oven seal
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Le Germania – oven seal
  • #36802
    Boonie
    We have a “Le Germania” which has been cleaned numerous times and whenever it is used creates a lot of smoke. It has also started to leave marks on the surrounding cupboards and the control panel. We think that the oven seal may need replacing (we estimate the oven to be over 5 years old).
    Has anyone else had a similar problem? Do you know of any suppliers of a seal for a Le Germania oven?
    Alternatively are universal seals good?
    Any suggestions are greatly appreciated. Many thanks in advance
    #252419
    Re: Le Germania – oven seal
    Not much out there to be found…….. La Germania brand name is owned by Bertazzoni in Italy. They don’t manufacture, so the product is bought in badged – some of the ovens are ATAG, hoods from China, etc.
    We’ll need a model number to have any chance of tracking it down for you.
    The service dept was ISDAL and we still get some work now and then refered.
    You will need all the information,Model No,Serial No ect.
    Give them a call on 08450508539
    Bryan
    #252421
    Boonie
    Thank you for your replies. I have located the model number etc. which is:
    Type: F6 68 02N
    Series: F6 6802N Var 00
    MATR: 2396 031115
    If the oven is creating a lot of smoke when it is on, is it likely to be the door seal? What else could it be?
    #252422
    Smoke is caused by burning – excess grease splattered over something getting hot. The door seal will only ensure that most of it stays in the oven box……….
    If the problem is that it is smoking then turn the oven onto the fan setting up to maximum temprature for 2 hours and then turn it to grill for 20 minitues and then if your oven has the standard conventional setting that one for 20 mins keep the kitchen door closed and the windows open.
    This will burn off any grease that has built up over the years.
    Bryan
