Re: Leak from Hotpoint BWM129. Help with door seal.
Thanks for that ,
going to take out in a minute an d see if i can see any loose connections etc. Hopefully i’ll see a blinding light and all will become obvious.
If turning the pressure down made a difference then you could try turning it down a little more.
Have you removed the dispenser drawer and given it a good clean, up inside the compartment as well as the drawer itself.
Right then,
the latest is i’ve turned down pressures , cleaned out detergent comparment ( which id done before ) and using less powder.
Seems not to leak now. Need longer to confirm but heres’s hoping !
