Leak from rear drum of washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Leak from rear drum of washing machine
  • #92923
    hozier
    Hoover OPH 716 DF Washing Machine.
    Had a major leak this evening.
    Accessed the back and the leak appears to be coming from a hole towards the bottom rear of the outer drum / plastic casing.
    The hole is about 6mm/3mm.
    To my eyes, because it looks ‘neat’ I thought it might be a specific drain hole (if they exist in case of problems?), if not and something has caused it, can the hole just be sealed – would this alone solve the problem?
    Tried uploading a video and an image but the forum says the image is too big?
    Any advice greatly appreciated.
    #452609
    Re: Leak from rear drum of washing machine
    you could put the video on utube then add a link
    try uploading the photo alone
    hozier
    Hope these links work.
    Definitely a hole made by a coin but has created a few hairline fractures too.
    Could I fix this with some sort of bond I.e. plastaid? Is there anything similar I could pick up straight away at screwfix / B&Q?
    Many thanks
    https://drive.google.com/open?id=1JzMhJQSiyojcW61mqUWRyc-a5HUL4l5-
    https://drive.google.com/open?id=1OqjsoHP0NHU_HJEc4esDjOghnN39FnRp
    #452611
    no the link wont work because its your personal space so we would need passwords
    there may be a way of doing it but I avoid google so I don’t know
    or you need to upload it to a public server for pictures or videos ( like utube for videos)
    hozier
    https://ibb.co/cB5yxG
    #452613
    thought I would edit your post to add picture
    yes seen this before. manufacturers answer is new drum
    my answer. look around the drum for a bit of plastic you can cut off. there is normally unused bits you can pinch somewhere. then with a soldering iron using the bit you pinched as filler melt the plastic to fill the hole. take your time and make sure you melt it all the way round to seal it.
    if there are tiny weeps when you have finished you can use silicone but don’t use it to fill the hole as it is not as strong as the plastic
    also try to look for the coin that’s caused it
    hozier
    Hi Dave,
    Thanks for the advice – I’ll take a look for the extra plastic.
    Is it correct that something like milliput wouldn’t work in this case? Never used it – just picking up ideas from previous posts I’ve read!
    Cheers.
    #452615
    don’t know have heard people have had good results but I have always melted it closed that way I know I have a good bond ( used Araldite with the old metal tubs)
    if you can find the bit that came out you could use that to start but don’t just put it back and melt it as you want it bonded all the way inside
