Hi Everyone
Thanks for your help in advance.
I have a SMEG DWF 410 SS. The machine stops giving error code E1 which shows that there is a leak somewhere and water is getting into the base of the machine.
I’ve opened up the bottom half of the machine and found that there is a leak from the connector seal to the water softner. I can also see a lot of residue on the sides.
I’m attaching a picture for your reference. I needed help with.
1. How can I remove the water softner? I am struggling as it seems to be attached to the top and I can’t figure out how to open it or replace the seals.
2. I’ve highlighted in the picture where the leak is (IN RED). I have also put in blue where the residue is, I can’t see any other leaks around this. But I can see that in the container there is a thick orange liquid. Is this meant to be there or is it just gunk that I can get rid of somehow?
Thanks in advance.
