My 12 year old AEG OKO Lavamat 605 washing machine has recently developed a leak. It doesn’t appear to leak during the wash cycle just when it’s pumping out the water.
I’ve had a nose around inside, the waste hoses appear to be fine. There’s no blockage and the don’t appear to be any leaks coming from the hoses and the pump appears to be working fine.
After it finishes pumping out some water settles around the pump, you can feel it in the hoses connecting to the pump, is this normal?
If so could it be a seal on the pump itself that is leaking?
Any help would be really appreciated.
Cheers
Jon
