My integrated Diplomat ADP 8242 is leaking during a wash cycle.
I took off the metal plate on the bottom and put it on a wash cycle to see what was going on inside.
From what I can tell, a small amount of water seems to be coming from a black pipe on the far left hand-side (which is attached to a white plastic pipe).
This seems to be happening as it’s filling up with water (although it takes a while for the water to actually make its way out of the bottom of the machine).
Assuming I need to replace this pipe, does anyone know if this is the kind of job I could do myself? I’m fairly competent at home repairs, but clearly no expert.
Or should I just get in an engineer?
Thanks.
