Re: leaking dishwasher
Hi. E/lux model DX6451.
First possible leak can be from the ventilation grill nut which is that grey plastic large threaded thing inside the machine on the lefthand side. Another favorite on these things is the top wash blades water conveyor pipe which is on the r/h/side at the back of the machine and can be seen with the panel removed-this hose/plastic pipe can leak either at the top or where it joins to the heater tube. Another favorite because I had another one 2 weeks ago is a pin prick sized hole in the s/steel tank which could be anywhere but the common place where they mess up is where the filter`s plate sits in to its tank recess- not obvious and the black tar stuff underneath can give you the impression the hole is in that area if tested with the front of the machine lower panel removed but the water has come via the hole 6 or so inches away having travelled between the tar and s/s tank. Typical d/washer, bloody pain to work on. B of Luck.
