Leaking door seal – Gorenje WA72145BK
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Leaking door seal – Gorenje WA72145BK
  • #88865
    samuelellis
    Good afternoon
    I have a Gorenje WA72145BK and i noticed today that if i run it on a 60 DegC or above cycle the door seal seems to let a small drip out of the seal where it joins the door
    If i run a rinse cycle or a lower temp cycle it seems fine. I have checked that the door and seal are both clean where they are supposed to seal together. Is this a sign thtat the rubber in the seal is starting to degrade
    #439612
    Re: Leaking door seal – Gorenje WA72145BK
    if its clean with no scale build up on the glass and still leaks then the seal needs changing
