Hoover Quattro. AS136 001. It appears to have a leak from somewhere near the front lower edge of the outer tub, not seen one leak from here before, very close to where the concrete weight is bolted through. Could this be a cracked drum or a faulty drum seal?
Sometimes the outer tub bolts loosen. Re-tightening can be enough to stop leak. On a few i have just applied silicone sealant to the outer tub joint, a bit awkward to do but better than removing tub.
Check first that the dispenser hose hasn’t got a hole in it or that it is water tight on tub.(it can leak when machine is spinning).
