Leaking incoming water hoses on Candy C1260
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Leaking incoming water hoses on Candy C1260
  • #45078
    Antocho
    The incoming water hoses on our Candy C1260 are leaking so I’m trying to replace them.
    The machine sits close up against the wall and so one end of the hose is at 90 degrees to the hose (i.e. there’s a plastic elbow in the hose). I’d like to get similar hoses, but the only ones I can find in the shop have normal straight ends.
    Just hoping you can point me at what I’m looking for.
    Thanks.
    #283537
    aqualectric
    Re: Leaking incoming water hoses on Candy C1260
    Do you need to have a 90 degree elbow at both ends of the hose? 90 degree at one end and 1.5metres (4 feet) long is the standard hose in red (hot) or blue (cold). They can be found in any DIY store or builders’ / plumbers’ merchants.
    If you can’t find what you need, e’mail Shop@ with your requirements. The link is to the left of the screen in the navigation bar. Dave will surely be able to help. 😉
    HTH,
    Steve.
    #283538
    Antocho
    Thanks. I only need the 90 degrees at one end — I just rechecked the shop and realised that the hoses there do have the bend (didn’t look properly last time).
    Cheers.
