Re: Leaking Indesit dishwashers. Is there a technical bulle
I heard this one aswell, the only tip I had, was that the new bottom seal fitted inside the well of the m/c [after removing the old ‘un from the base of the door],then to protect the new seal you had to put some kind of tape over the sharpe edge on the base of the door. They quoted some part # that turns out to be obsolete :rolls: but all is not lost, get a hold of some of that aluminium foil tape that Hoover engineers used on the Starlite model vacs, it’s the same stuff! I’ve done a couple & so far so good, but typical Merloni design 😈 👿 .
Hope this helps ,cheers Chris.. 8)
