Re: Leaking Indesit IDF125
I replaced the “Air Break & Turbine” as advised and the machine worked OK for 6 months.
However the issue has returned. When the water starts to fill the machine the water pressure seems to high and it overflows from the Air Break.
It could be the Air Break again but is it worth trying anyting else?
Someone above said it could be the pressure switch but this doesn’t look like it it attached to the Air Break. The watler inlet valve (see photo) feeds the Air Break could it be this that is at fault? Is there any way to test it with a multimeter?
Any advice greatfully received.
