Help this is causing real problems.
It’s leaking from the bottom of the screw in filter at the front of the machine. My husband thinks it’s a crack in the drainage “boot” however my thoughts are more towards the screw in filter basket and it’s seal system.
The machine gets used a lot for washing dog blankets so the filter is cleaned often and we do regular tub cleaning washes too. We also have a water softener fitted as we live in a hard water area.
I’ve taken the filter part and given it a good clean and made sure all the seals were tight and put silicone grease/gel stuff on that my husband gave me and it still leaked when I tested it out. I thought if the boot had cracked/ perished it would leak out of the bottom of the machine.
Any help would be really good, I haven’t even been able to track down the filter so I can replace it and see if that works!
Many thanks
The last lg I repaired-last week- which was not your model number had a leak from the dispenser hose (which is common)in which the water ran down the circumference of the tank and dripped at 6o/clock , ran towards the pump area on my model which is on the left of the machine as the floor sloped that way and gave the impression that the pump/filter was leaking or that the tank seal was leaking when looking underneath when this was not the case at all-£10 hose fixed the problem……….long shot for your problem but a point none-the-less.
