Leaking tub gasket Servis M3025
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Leaking tub gasket Servis M3025
  • #26056
    spinbin
    Hello. I’ve just replaced the bearings on this machine and have a small leak. It’s the type with a rubber gasket and clamp ring.
    The joint faces have been thoroughly cleaned but I’ve noticed there is an uneven section on the backplate where the leak is. Looks like it’s preventing full contact with the gasket.
    I’m repairing this on the cheap as you might expect, so planning on using some silicon sealant on the leaky section.
    I’ve seen mention of debor adhesive on the forum and this is probably the right stuff to use, but seeing as I have some silicon already, will this be ok?
    By the way, I’m not planning on repairing this machine again so not bothered if it’s sealed for good. Cheers.
    #208596
    Re: Leaking tub gasket Servis M3025
    Silicone sealant will be just fine…. 😉
    #208597
    spinbin
    Thanks for the speedy reply Martin. Silicone it is then.
    Excellent forum by the way :happy:
