Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Leaking whirlpool G2P DWI
- This topic has 8 replies, 2 voices, and was last updated 17 years, 1 month ago by
susangiraffe.
March 28, 2009 at 6:26 pm #44594
susangiraffe
ParticipantGrrrrr 👿 Dishwasher decided to play silly buggers this week! Firstly the dishwasher tripped the RCD, left it off for a few days, when I switched it back on it started working. Today however it has decided to leak from the bottom. I put it on a rinse cycle, and it seemed to work…water filling up and draining away. Put it on a 40 degree cycle and the water is pumping out, but is also leaking from the bottom again. Light flashes and beeps continually…
Has anyone any idea what is causing this? Whether it is expensive to fix? Can I fix it myself…… any feedback would be appreciated!
March 28, 2009 at 6:44 pm #281535Penguin45
ParticipantMarch 28, 2009 at 6:56 pm #281536susangiraffe
ParticipantRe: Leaking whirlpool G2P DWI
Thanks for the reply!! Will it be obvious that this is the fault if I look underneath the dishwasher…dont really want to fork out for a new part if thats not the problem….
March 28, 2009 at 7:02 pm #281537Penguin45
No. It’s easier to remove the lower front panel and look in from the front.
Power off for anything other than observation.
March 28, 2009 at 7:10 pm #281538susangiraffe
Thanks Penguin45…I’ll have a look tomorrow! Is it fairly straightforward to take out old pump and replace a new one?
March 29, 2009 at 12:31 am #281539Penguin45
On the surface of it, it’s quite straightforward. Two wires, two hoses, two screws. Lay the machine on it’s left hand side, remove the base panel and it’s all laid out for you.
The catch is the hose clips. These are a “crimp” type and are no longer included with the new motor, so you have to re-use them. You’re going to be looking at something very like this:
HTH,
March 29, 2009 at 8:16 pm #281540susangiraffe
Hi Penguin45….took off the front, and the bottom of the dishwasher, fault is exactly as you said….pump is leaking from outlet hose…and just getting worse! Will be ordering new part as recommended! Thanks….will let you know if it fixes the problem! Here’s hoping!!!
Thanks again 😆
April 5, 2009 at 9:07 pm #281541susangiraffe
fitted new part….working like new! Dead easy to fix too! (and I am a blonde female lol) Thanks for your help, couldnt have done it without you!!! 😆
April 5, 2009 at 10:58 pm #281542Penguin45
susangiraffe wrote:Dead easy to fix too! (and I am a blonde female
Well done. Don’t put yourself down – there’s far too many people out there who’ll do that for you if you let them.
