Leaking Whirpool adg 7550
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Leaking Whirpool adg 7550
  • #48707
    quietlife
    My dishwasher started tripping the electricity a couple of days ago. Took the bottom panel off and the tray was full of water. Dried it off it started working again. However, there was initially a small drip, which turned into a pretty heavy leak when it got to the drain cycle. It looks like the water was coming out of the top of what I think is the pump
    Can this be fixed, or is it now scrap
    (Great forum by the way, very informative)
    #297420
    quietlife
    Re: Leaking Whirpool adg 7550
    Ok. A bit more digging. It wasn’t what I originally thought. It’s a split pipe.
    I’ve removed one end of it. Is there a way of just replacing the pipe or do I need the whole unit it’s attached to.
    #297421
    Better have a read of THIS ARTICLE.
    quietlife
    Many thanks for that. Am I right in thinking I can’t just replace the black bit! (Sorry for the non-technical term 😀 )
    #297423
    No, it isn’t a spare part. Many have tried with odd off-cuts of hose and jubilee clips, most fail 🙁 .
    racingredchief
    I’ve replaced just the pipe before , you can get them on their own from some suppliers , if not so long as the pipe is of the same circumference at the joins and a similar shape , so you don’t need to bend it will be ok
    #297425
    quietlife
    I was supplied with a new ‘black cover’ but I just can’t get a seal around the small black pipe. It’s seems to run at such high pressure that it squirts out around the connection. I’ve tried it dry, with leak stop and with gasket sealer. I’m now losing the will to live.
    Any suggestions.
    (Also, when I took the old cover off, I had to take the magnetic armature out, as it as so tightly fitted on. I’m a a bit worried this may have damaged the motor)
    #297426
    racingredchief
    it wouldn’t happen to be a clamp fastened part
    #297427
    Crimp rings…….. You either know how to re-fit them or you don’t. The “Knack” can be difficullt.
