Leaking Zanussi ZDI6895QX
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Leaking Zanussi ZDI6895QX
  • #59536
    skins2
    We have a leaky dishwasher. It’s a Zanussi ZDI6895QX (serial: 22010036). Water is pouring from the left-hand side of the machine.
    I’ve emptied the red tube, which was full of water, next to the water feed – an engineer said to do this if we have any problems in the future.
    I’ve also shut the water supply off and run on a rinse cycle to try and drain the water but as soon as I turn the water back on and run a cycle it leaks again. When running a cycle it stops and either the red tap icon flashes or the error code AL4 appears.
    The pump sounds like it’s working (usual wurring noise).
    I’ve just taken the side panel off and it’s leaking from 3 small holes at the top of the side blue tank. Pics:
    Any help with fault-finding will be appreciated.
    #338579
    spanishwhite
    Re: Leaking Zanussi ZDI6895QX
    I’m not an expert on dishwashers,however I think you have answered your own question.
    The leak will be coming from the holes you have found in the iwms(the blue tank)
    #338580
    skins2
    spanishwhite wrote:I’m not an expert on dishwashers,however I think you have answered your own question.
    It would be the answer if those holes were not there when I bought the appliance, but they were. You can see they have a moulded flange at their opening and I assume they’re there to allow air to escape and to prevent the tank pressurising too much, not to leak water.
    Do any other Zanussi dishwashers have a tank similar to this with holes in the top?
    #338581
    CJAPeterborough
    Not familiar with this model but the holes in the top of the matrix are almost
    certainly safety/overflow vents.
    you probably have a blockage which is preventing the water being recirculated.
    Try and check the hose connections from the matrix to the sump
    -also in your pic the bottom third of the matrix seems to be completely gunged up?
