Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Leaky Bosch
- This topic has 7 replies, 2 voices, and was last updated 5 years, 10 months ago by
Al RandomNights.
June 9, 2020 at 7:07 pm #97793
Al RandomNights
ParticipantHi guys. I was wondering if you guys might be able to shed any light on what seems to be an unusual leak as cant find any info online about it.
I have a Bosch Silver Edition SMS40A08GB/29
and it got the common e15….I think that what it was….error showing water in the base water trap. Son pulled the side off to take a look and sure enough it’s wet in there. Thing is the water is coming from behind the power unit from a little tab in the base plastic. It looks like the water could either be coming from between the metal and plastic or possibly from the water feed to the top water sprayer up thr back?
I can’t see how water cold possibly be coming from the feed or return as is lower than this point and all dry.
can anyone offer any help as I can fix most stuff bit this one shirt of stripping the full. Machine down has me Baffled.
Many thanks Al 🙂June 9, 2020 at 7:38 pm #469529electrofix
Moderatorwe have problems with Bosch machines where the stainless interior joins with the plastic base. check at the rear when its in use
June 10, 2020 at 8:14 am #469530Al RandomNights
ParticipantIt doesn’t seem to be leaking on the exterior that I can see, just from that small hole. Is that something that can be fixed cost effectively? Tx 🙂
June 10, 2020 at 8:23 am #469531electrofix
Moderatorshort answer dont know
its a very unusual place to leak but i dont think thats the leak its just showong at that point
as a test i think i would put a peice of tape over the hole and run the unit when its out. then see if water appears anywhere else
June 13, 2020 at 10:34 pm #469532Al RandomNights
ParticipantI’m going to try sealing it with high temp silicone round the join inside the machine. Hopefully will work and not poison the pots! 🙂
if not it’s going down the side of the house. Cit s hole in the bottom to let water out the trap and it’s a new car parts cleaner!! LolJune 13, 2020 at 10:47 pm #469533electrofix
Moderatoryou can get silicone for food use and the temp is not that high but you will have to research if its suitable
June 15, 2020 at 12:20 pm #469534Al RandomNights
ParticipantI came to seal it and can see there is a difference side to side in the gap between the plastic base and the metal top. I sat my son on top, screwed together and have sealed with high temp silicone. Fingers Xd. Tx for your help
June 15, 2020 at 12:52 pm #469535electrofix
Moderator“I sat my son on top”
hope you made him sit there for a few hours till it set lol
