Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Leaky Hygena ADL 8212
- This topic has 7 replies, 4 voices, and was last updated 20 years, 3 months ago by
Nina.
January 3, 2006 at 10:08 pm #14492
Nina
ParticipantThe Hygena ADL 8212 is leaking!
The water seems to be coming from the underside and only comes out during the rinse and dry part of the cycle. The filter is unclgged and clean.
Does anyone have any suggestions?
Many Thanks 😀
January 4, 2006 at 12:13 am #159645Penguin45
ParticipantRe: Leaky Hygena ADL 8212
I would suspect a problem with the drain hose if it completes the wash sequence.
Power off if investigating further, or click the link below for a UKW engineer in your area.
Penguin45.January 4, 2006 at 7:52 am #159646kwatt
KeymasterCould also be condensing steam on the outer door dripping down if the door isn’t closing properly or the seal is a bit tired.
January 5, 2006 at 3:25 pm #159647Dave_Conway
Nina wrote:Thanks for the previous help. There is no prob with the door seal, and the draining hose is fine.
The leak seems to be coming from the left side (as you’re looking from the front) of the underside, and only when in the rinse part of the cycle.Any more suggestions??
Moved here to keep it tidy, other post deleted 😀
Check the upper (ceiling) spray arm, where the water enters the plastic inlet tube splits and water will leak on to the roof of the cavity 😉
January 5, 2006 at 4:00 pm #159648Nina
Many thanks Dave.
Have found the leak, just not sure how to fix it!
It’s coming from the top of the spray arm where it enters the dishwasher. There are no splits in the plastic. Thinking the washer might need replacing, but should I look for anything else too?
Nina
January 5, 2006 at 4:02 pm #159649Nina
Bloody computers! Sorry for the multiple posting of that message, was not intended!
January 5, 2006 at 4:14 pm #159650Dave_Conway
Multiple postings sorted 😀
You need a kit, part number 31X3801 at £41.83 inc VAT and carriage. You get the water inlet pipe, upper spray arm all the washers/fixings etc, quite a common fault on these 😉
An email to spares@ukwhitegoods.co.uk please if required 🙂
Power off of course if attempting yourself, if you need an engineer, please check the repairs@ link below.
January 5, 2006 at 4:55 pm #159651Nina
Thank-you for all your help. The spray arm fell apart as it came away from the dishwasher! Have sent an email as you suggested for the kit.
Again many thanks!(Will probably hear from me again when trying to put it together!) 😆
Nina 😀 -
