Leaky Zanussi(es)
  • #79832
    twicknix
    Been to two jobs and both have leaky inlet hose on the rear of the machine. One caused intensive damage to the flooring.
    Warning, always check the tightness of inlet hose on Zanussi washers.
    #410788
    Re: Leaky Zanussi(es)
    I hope they weren’t fingering you for these leaks? It’s more likely a ‘Currys Knowhow’ error you’re describing, limp wristed delivery men and such.
    #410789
    twicknix
    Martin wrote:I hope they weren’t fingering you for these leaks? It’s more likely a ‘Currys Knowhow’ error you’re describing, limp wristed delivery men and such.
    I’ve never been to the two addresses, so I’m safe on this one. I think I might be asked to compile a report about the job as there was intensive damage to the kitchen due to leaking inlet hose for the last two years.
    I could not return the machine back to the position in case of the wood/flooring dries out and the weight of the machine may fall through it. The water was holding the floor together!
