Lec D110 dehumidifier fault
  • #36059
    bzz67
    Lec D110. we have this dehumidifier in the workshop 4 repair. when we turn it on low, the fan runs, but when we turn the humidistat up, the compressor begins to run and the fan stops. we cant seem to get them both running together. any suggestions?
    #249396
    Re: Lec D110 dehumidifier fault
    Are you sure it’s not on the defrost cycle (small timer inside IIRC)?
    Fan won’t be running during defrost.
    Mike.
    #249397
    bzz67
    yes we’ve advanced the timer round but still no different. in defrost it will be sending hot gas, but it is freezing as it should, just no fan.
    #249398
    The thing must be getting on a bit. Wouldn’t think it worth much of your time unless it has sentimental value!
    Mike.
