Re: LEC T2855W Fridge freezer freezing in fridge
The likeliest culprit is the diverter valve located adjacent to the compressor, mounted on the left hand upright of the cabinet (as viewed from the back). There is a pcb inside which is prone to melting. The best way to cure is replacement of the complete unit which is a systems job. I have known colleagues solder just the pcb in with success, but if the pcb shows no sign of burning whole unit will need to be replaced as it is possible for valve to stick. Personally I prefer to replace the whole unit.
