Left hand hinge for KG33NA40GB/04
Home Forums Public Support Forums Spare Parts Help Left hand hinge for KG33NA40GB/04
  • #79572
    rioq
    Can anyone please let me know the part number for the upper left hand fridge mount?
    Many thanks in advance,
    Peter
    #409807
    don
    Re: Left hand hinge for KG33NA40GB/04
    The only Siemens machine I can find similar to yours ends GB/01 if this is the one the explosion and parts list is here It looks like the hinge is made up of several components.
    To access the explosion click on spare parts list and diagrams button.
    HTH 🙂
    Don
    #409808
    rioq
    Thanks Don,
    On that diagram the part number I am after is 0146, but for the left side (which I cant see on the diagram). 0146 is non-reversible.
    Peter
    #409809
    don
    No mention of any top left hinge. Either that one is reused by turning it over and refitting the pin if it unscrews or that model of appliance is not capable of hanging on the left side.
    What does it say in the user manual about door reversal? Sometimes opposite hinges are supplied FOC with the appliance.
    Don
    #409810
    rioq
    Thanks again for your reply. I purchased the fridge second hand recently, and did not have a manual or any spare parts. I have since managed to get hold of a PDF version of the door reversal (Which I could email me you if needed?). I could also send photos of the part in question and how it is a rigid mold with R stamped on it. The pin can not be reversed.
    Peter
    #409811
    don
    Just sent you a private message 😉
    Don
    #409812
    don
    Hi Peter
    Looks like the top left hinge comes with the appliance as an accessory.
    In which case it well may be worth contacting Siemens spares direct from their website.
    Make sure you have the following to hand before making contact. The full ENR number and the FD number.
    Don
    #409813
    rioq
    Thanks Don, i’ll give that a go and let you know how I get on.
    #409814
    rioq
    Siemens are saying that there is no part or accessory for the left hand fridge mount, mind you they are also saying that no revision 04 (as per my plate – KG33NA40GB/04 – FD8711).
