Left hand side of cooker not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Left hand side of cooker not working
  • #63062
    coreservers
    I have a Leisure Alta cooker. yesterday I switched the grill on and hte light came on momentarily, then went off. and the grill stopped working.
    I tried turning the oven on and it is fine. however I switched the left hand rings on the ceramic hob and although the hob light came on the rings didnt heat up. the right hand rings are fine.
    it seems anything linked to the knobs on the left of the timer clock is not working (the clock is fine however.)
    any ideas?
    #352385
    Re: Left hand side of cooker not working
    Can you give us the model number?
    coreservers
    Hi There
    it’s AL6CDW
    #352387
    Have a look at the mains terminal block at the back to see if it’s either burnt or one of the links has come adrift/been burnt out.
    coreservers
    inside (removing the back) or just remove the external mains cover?
    #352389
    You should see it behind the mains cover.
    That’s the most obvious thing it could be, beyond that things get a LOT harder.
    steve1
    mains terminal block faulty needs replacing
