Leibherr fridge freezer problem.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Leibherr fridge freezer problem.
  • #90384
    Timcooper55
    Service number 0905862 – 00
    Serial number 43.022.012.2
    Model number 7081 946 – 00
    We have had same problem for about 3 months now, about once a week.
    The alarm will go off. So we turn the alarm off, put the boost on, turn the temp control to full coldest setting, then leave it for about an hour or so, or longer.
    Then everything seems ok, so put the temp setting back again and all is well until next time.
    We did turn it off for 24 hours to give a complete defrost also.
    Any ideas please?
    5 years ago we had a different problem in that the fridge wasn’t cooling properly all of the time. An engineer came and according to his receipt he fitted a sensor kit 9590142.
    Tim
    #444608
    SAMURI
    Re: Leibherr fridge freezer problem.
    Possibly a faulty sensor or a fault on the defrost system.
    Bob
    #444609
    Tony R
    Hi Tim,
    Are there any of the green display blocks flashing in sequence with the supercool button light when it alarms.
    Tony.
    http://www.liebherr-randallrefrigeration.co.uk
    #444610
    Timcooper55
    Hi Tony & All,
    Thanks for replies.
    We can’t remember if the green block lights were flashing or not.
    But will look next time the alarm goes and let you know.
    Thanks again,
    Tim
    #444611
    don
    Hi Tony
    Have you ever thought of applying for access to the trade forums? Link here if you wish to join the dark side 😉 there is a wealth of help, good banter along with lots of info, and much more.
    Don
    #444612
    Tony R
    Hi Don, yes, and I did send a request to join the Trade section, but never heard anything back, did it over a year ago.
    Tony.
