LEISURE 110 LPG spare parts numbers required please .
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts LEISURE 110 LPG spare parts numbers required please .
  • #97598
    garn
    Leisure 110 S/n 5690002502 LPG.
    Hello im looking for several bits for this appliance part numbers
    LPG JETS x 5 and most of all the diagram configuration fitting sequence.
    2nd thing the shaft bar extension for the oven energy regulator dial which is broken.
    been looking for a week.
    thanks Paul
    #468582
    need more info
    most likely made by Beko so need complete model or product code
    to give you an idea what i am looking for CK110F232R product 7726586357 plus serial no
    not sure what you mean by diagram configuration fitting sequence
    garn
    apologies for the late response Dave.
    Model LEISURE EBX110FRX S/n 5690002502
    LPG JETS Required plus ignition button.
    the configuration details are the individual numbers for the jets .
    each jet only fits 1 particle burner
    example left hand front burner jet no 20. if the wrong jet is fitted to the wrong burner the flame would be out slightly or wrong color when its lit. these details normly come with the handbook which we don’t have.. (they do with electrolux)
    regards paul.
    #468584
    are you sure that model is correct as am not getting any hits anywhere including google which is normally proof the number is correct
    garn
    sorry digit out
    Model EB10 FRX S/N 5690002502.
    #468586
    well i have searched placed on the beko site i have never searched before. I know they produce injectors to convert this cooker but they only list the NG ones. Manual gives method but thats all
    unless anyone else on here knows where to get the info i suggest you get the customer to ring leisure as i think they may supply these FOC, but dont know for certain
    kaibart
    The jets are all different and they go into each burner hob, you should be able to work it out by removing 1 at the time and the jet will have a number printed on it so 1 for 1
    #468588
    kaibart wrote:The jets are all different and they go into each burner hob, you should be able to work it out by removing 1 at the time and the jet will have a number printed on it so 1 for 1
    injectors fitted for NG are
    1Kw M072
    2Kw M103
    3Kw M115
    kaibart
    There has got to be 4 different jets listed for hob as there is 4 different size burners
    #468590
    kaibart
    Here is what I mean by stamped on what beko call injector and connect has 4 listed but all for natural gas so oven may not be compatible for lpg
    #468591
    my post above is from manual and says about conversion so they must be available
    yes just seen M140 3.3Kw as well but in typical Beko style they have the same diagram number twice
    garn
    Thanks dave .
    i will inform the customer
